2023-02-24 03:30 PM
Good day
Working with cavity walls and placing windows & doors it's easy to have cavity skins return at the openings, but is there a way to have any sort of closure when you use empty doors/windows or even the opening tool? How can I close these openings please?
Thank you in advance.
Solved! Go to Solution.
2023-02-24 05:07 PM
With the window opening object
2023-02-25 07:37 PM
Use the Objects from the "Empty Door Opening 26" folder, 2 lines above in your image.
2023-02-24 05:07 PM
2023-02-25 07:37 PM
2023-02-27 11:44 AM
Thank you very much - I didn't realize that it's different to use an empty door/window opening rather that changing a door or window to "use as empty opening". This works great and I appreciate your time and advice.
2023-02-27 11:44 AM
Thank you so much - I didn't realize that it's different to use an empty door/window opening rather that changing a door or window to "use as empty opening". This works great and I appreciate your time and advice.
