Wall closure - Empty doors & windows
Thinus
Good day
Working with cavity walls and placing windows & doors it's easy to have cavity skins return at the openings, but is there a way to have any sort of closure when you use empty doors/windows or even the opening tool? How can I close these openings please?
Thank you in advance.
2 ACCEPTED SOLUTIONS
Yves
With the window opening object
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
BrunoH
Use the Objects from the "Empty Door Opening 26" folder, 2 lines above in your image.
ArchiCad 3.43 to 28
MacOS Monterey
4 REPLIES 4
Yves
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
BrunoH
ArchiCad 3.43 to 28
MacOS Monterey
Thank you very much - I didn't realize that it's different to use an empty door/window opening rather that changing a door or window to "use as empty opening". This works great and I appreciate your time and advice.
Thank you so much - I didn't realize that it's different to use an empty door/window opening rather that changing a door or window to "use as empty opening". This works great and I appreciate your time and advice.
