ā2024-05-02 12:36 PM
I like to model a cove like this in the wall corner, tried opening tool but couldn't achieve it, I don't know it's a painting finish or special blocks stacked to produce this beauty.
If anyone knows how can this be modelled in Archicad? thanks.
Solved! Go to Solution.
ā2024-05-02
04:47 PM
ā2024-05-08
12:43 AM
If you really need to model every line of the plaster, even the curved corner, then you could use Substract from Solid Element Operations (SEO):
Beware of this method of SEO can result in a slower performance for your file if it is widely used. Maybe you could only substract the curved corner and get the plaster lines based on the building material surface.
Regards.-
ā2024-05-08 12:58 AM
You could also use Columns and Beams to create the grooves. Put them on a wireframe layer with the same Layer Intersection Group Number as the Wall and a Building Material with a higher Intersection Priority Number than that of the Wall, Archicad will apply Priority-based Connections, and they will automatically cut the Wall, no need for SEO for that. The wireframe Layer will enable you to see the geometry of the cutting bodies without them obscuring the geometry of the Wall. After they are modeled, their layer can be hidden.
When you model the grooves, make sure the 3D bodies of those Columns and Beams touch, but do not collide/intersect - that way you will have fewer automatic Priority-based Connections Archicad has to calculate. (Priority-based Connections are SEOs automatically performed by Archicad, just like SEOs a user explicitly performs on selected elements.)
ā2024-06-21 07:32 PM
Hello @Mahmoud Qenawi,
If you're still interested into the argument, there are the Youtube link of the webinar(it's in Italian and divided in three parts), there is also the presentation of the new HBIM library parts, but I think that them will be available only for Italian SSA/forward users.
https://youtu.be/pYxkYHZ91yM?si=WAP2QsiXFFR8d_rA
https://youtu.be/ALOPNv0l3A8?si=-_a3ncEsi5ieVl2-
https://youtu.be/ArBgUqpBWYY?si=Kk2uCTtrgOhFAy1m
ā2024-05-02
04:47 PM
ā2024-05-08
12:43 AM
Regards.-
ā2024-05-02 09:30 PM
Perfect, thank you @Ricardo Lopez.
fantastic way of thinking I really didnāt imagine,
Only more morphs for the whole elevation.
ā2024-05-03 09:26 AM
Hi @Ricardo Lopez,
Do you think this facade was created also by SEO? Just guessing.
BTW these photos are captured from Graphisoft Italyās LinkedIn post.
ā
ā
ā2024-05-03 09:49 AM
I would say, probably yes.
But a column and arch could also be modelled with individual components and then saved as an object or a module and then repeatedly placed.
And these days with the segmented column, the column up to the arch could be all done with just the column tool.
ā2024-05-03 01:24 PM
If you refer to ashlar(I hope is the right term), them was realized with the curtain wall tool,
We have a very interesting Webinar on HBIM approach organized by Graphisoft Italia and the architect that have done this model(I can't remeber his name in this moment).....I think that in next weeks you could find the registrati on the Graphisoft Italia youtube page
ā2024-05-03 05:31 PM - edited ā2024-05-03 06:47 PM
Thank you Barry,
I hope this object can be created by paramo itād be easier to update with design modification & also if segmented column feature is available for complex profile one that will save much time.
ā2024-05-03 05:45 PM
Thanks, sure Iāll search for this webinar & if you got a link for it pls post it here.
Curtain wall tool can be effective also for this challenge despite canāt imagine how it works.
ā2024-05-08 02:50 AM
Thank you @Laszlo Nagy ,
I think it wonāt affect the overall performance but still the corner void needs to be done by morph & SEO.
