Wall corner not cleaning up properly
I am a new Archicad user (migrating from Revit) am discovering all the quirks that don't show up until you have to do some real work. The wall intersection in a T formation cleans up nicely. The exact same walls where the interior wall meets a corner don't clean up properly. The priorities are correct. I have tried all manner of placing the walls but nothing works. Any suggestions?
KrisM
2 Replies 2
insideru
Whenever it comes to intersections it's usually the priorities. Also make sure that your walls' ref lines are properly connected.
ARCHICAD 28 INT
macOS Sequoia
Okay, thanks. I got it to work but had to play around with the drawing order to get it to cleanup. Quite a bit more fussy than Revit but I know Archicad excels at other things.
