shenni
Wall hatching not showing
Hi eveyone!
My wall hatching from my previous save is showing but when I draw a new wall, it doenst show any hatching.
I check the model view settings and make sure the wall layer is turned on too, but the hatching is still not showing. Does anyone has a solution to this ?
Thank you in advance !
2 Solutions
Lee Hankins
It could be that the walls are on different renovation filters or the wall not showing the hatch has a lower height so it doesn’t pass through the floor plan cut plane.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Go to post
runxel
It's your wall height. As seen on your screenshot it is 61 centimeters, which is below your floor plan cut plane of most possibly 1 meter. So you are just seeing the outline.
Go to post
4 Replies 4
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
runxel
shenni
ah yes! thank you so much!
shenni
yes i realised that now! thank you so much !!
