We value your input!
Wall hatching not showing
shenni
Hi eveyone!
My wall hatching from my previous save is showing but when I draw a new wall, it doenst show any hatching.
I check the model view settings and make sure the wall layer is turned on too, but the hatching is still not showing. Does anyone has a solution to this ?
Thank you in advance !
2 ACCEPTED SOLUTIONS
It could be that the walls are on different renovation filters or the wall not showing the hatch has a lower height so it doesn’t pass through the floor plan cut plane.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.2.2 | Archicad 28 Apple Silicon
macOS Sequoia (15)
runxel
Legend
It's your wall height. As seen on your screenshot it is 61 centimeters, which is below your floor plan cut plane of most possibly 1 meter. So you are just seeing the outline.
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
4 REPLIES 4
Lee Hankins
macOS Sequoia (15)
runxel
Legend
ah yes! thank you so much!
yes i realised that now! thank you so much !!
