‎2022-12-09 04:03 PM
Hi eveyone!
My wall hatching from my previous save is showing but when I draw a new wall, it doenst show any hatching.
I check the model view settings and make sure the wall layer is turned on too, but the hatching is still not showing. Does anyone has a solution to this ?
Here is a screenshot of my view
Thank you in advance !
Solved! Go to Solution.
‎2022-12-09 05:30 PM
It could be that the walls are on different renovation filters or the wall not showing the hatch has a lower height so it doesn’t pass through the floor plan cut plane.
‎2022-12-10 05:44 PM
It's your wall height. As seen on your screenshot it is 61 centimeters, which is below your floor plan cut plane of most possibly 1 meter. So you are just seeing the outline.
‎2022-12-17 12:22 PM
ah yes! thank you so much!
‎2022-12-17 12:23 PM
yes i realised that now! thank you so much !!
