ā2014-05-14
08:21 PM
ā2023-05-24
09:00 AM
Rubia Torres
ā2014-05-15 06:42 PM
ejrolon wrote:My point is that you should not need to save the layer intersect numbers after you change them because they are resolving a graphic anomaly that you will want to have resolved in all possible ways you might ever want to view the affected parts in the 3D window. Not just one View map controlled by one Layer Combo like you would do to resolve a display issue using Junction Order, Display Order, Material Priorities...
I use layer intersect numbers to control SEO issues (I have always used slabs for SEOs and with PBCs they need a different number), control Overhead Items in plan and to be able to control and fine tune Renovation filter problems. In all cases being able to specify different layer combinations have saved me lots of time.
ā2014-05-15 07:36 PM
another Moderator
ā2014-05-15 08:29 PM
ā2014-05-16 04:15 AM
JPL_DESIGN_GUY wrote:Is it because you are now using version 17? (please add your Archicad version and Operating System to your profile signature or mention it in your posts).
My log walls are a profile that I created to match our logs which I haven't changed or created newly. Even older projects with log walls are doing this. I am not great with this software but will try to create a new log wall profile and see if that corrects the issue. Thanks!
