MuriloNoleto
Wall - representation on floor plan
Hi folks!
I made a column in a intermediate level (see the attached pic #1), between two stories. However, the column isn't showed in a original level, only on the stories above (see the attached pic #2).
How is the correct way to adjust the definitions of "Floor Plan Cut Plane" and "Floor Plan & Section" to represents the column correctly? I tried to study this contents but i need help.
Thanks!
#01
http://postimage.org/image/nv1rqyf8/
#02
http://postimage.org/image/nvdcidvo/
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 29 | Win 11 |
3 Replies 3
Are you sure that the column is on the Story 0?
Seems to be on Story 1 with the setting for "Show on Stories= Home & One Story Up".
I have no problems with my column that has elevation 200cm from the Story 0.
MuriloNoleto
Andro,
Actualy, that column i made with wall tool.
Both tools (wall and column) have the same problem in your representation.But, your help (using an object) resolves like a palliative. Later i will study this problems again.
Thank you very much.
Murilo Noleto
I would have thought setting the wall to All Relevant Stories should fix your display issues.
