Denissss
Wall surfaces
I am evaluating the trial license of Archicad 26. Very new to the program. So basic questions coming :). Tried forums and resources, but as of now cannot find my answers.
Two things that I cannot figure out:
1. How to change the window casing color? 
2. Why is the wall override surface not joining at the corners (picture)? I just created a new composite with 3 layers/skins and overridden the surface. Every time I draw walls that I created or use default walls and override the outside surface this happens.
Archicad 28 Solo, Windows 11 Pro, Dell Precision 7560 Laptop (64GB RAM, i7-11850H, RTX A4000), Dual 27-inch Dell Monitors (2560x1440).
1 Solution
Guru
https://help.graphisoft.com/ac/25/int/_ac25_help/020_Configuration/020_Configuration-53.htm
Go to post
3 Replies 3
Guru
Denissss
Thank you.
So obvious checkboxes and I just missed these searching around 😄
You will miss many things by just looking around.
Be sure to look at the resources in the HELP menu, in particular the YouTube channel and the Learn Portal.
The best way (but not always possible) is to have someone, that knows Archicad already, show you around or to be there to answer your questions by showing you on screen.
