Wall texture intersection
Hello, i am using the same wall and texture on both walls, but the texture do not align.
It is a wall made of the same two layers (one brick and the exterior insulation). The texture is stopping exactly where the insulation begins. What should i do to have them aligned?
Thanks
13 Replies 13
James B
drexdis wrote:
@James B, in 3d i know how to align the texture manually with texture origin, but the texture fill for the facade i don't know why it's not getting also the same origin.
I'm not near AC right now so I'm having to guess a little. The image texture and vectorial hatching are linked (as far as I know) to the same element origin.
1. Try selecting both walls and reset texture alignment
2. In 3d try changing to internal engine with vectorial hatching on
3. Try aligning the texture of both walls to the bottom corner of both walls
James.
James Badcock
I've tried what you said, the problem still exists, the texture doesn't align.
Any other solution for this?
James B
I can only suggest that in 3D, use Internal Engine, with Vectorial Hatching on. Then manually align the texture. With one Wall selected, use the Design > Align 3D Texture > Set Origin feature.
James Badcock
Katalin Borszeki
HI All, the current solution for this problem in ARCHICAD18 has been described in James B-s post and the issue has been fixed in ARCHICAD19!!
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
