2025-08-18 09:51 AM - edited 2025-08-18 09:51 AM
Hi!
I'm having a problem with walls not joining in plan. Clean Wall Intersections option is turn on and the walls are on the same layer and priority.
I there any other option I'm missing out that affect he walls connections?
Solved! Go to Solution.
2025-08-18 12:50 PM
Since AC27 there is an bug with renovation filter that sometimes occcur.
Try to open Renovation filter settings and without changing anything click OK.
2025-08-18 10:12 AM - edited 2025-08-18 10:32 AM
Are no walls joining, or just a few?
Next to clean intersections and layers+prio I would add Reno.
Or, a special case: zero height walls.
Sometimes when moving walls they do not intersect again cleanly. Trying to rejoin reference lines helps there.
2025-08-18 10:40 AM
Make sure layer priority is not zero.
Any other number is fine.
2025-08-18 11:02 AM
Every now and then I run into this problem as well: suddenly no wall connects to any other wall anymore. The only thing I found that worked was starting a new file and merging it with the other one via File > Interoperability > Merge.
Would like to know if there are other options....
2025-08-18 12:50 PM
2025-08-18 01:05 PM
