We value your input!
What should I understand as a line that is visible in 3D VIEW but not visible in a floor plan ?
LeeJaeYoung
What should I understand as a line that is visible in 3D VIEW but not visible in a floor plan or elevation view?
Because of this, I spent a lot of time in 3D, but I gave up because it was a line that did not appear in the elevation or floor plan.
AC27 on window 11
Guru
AC issue regarding intersections and thin surfaces. As you move your camera around some of these instances will disappear while others will appear... They should not appear in renders though.
LeeJaeYoung
thank you so much.
10mm finish is available.
I don't know, I've spent too much time ^^
AC27 on window 11
