Why are there two Origin Points showing in my model?
BenATA
Hi All,
I am curious to know why are there two Origin Points showing in my model?
See image below:
Thanks!
Ben
AC23
ā€ƒ
Ben
ArchiCAD 23 -amp; 26
MacOS 12 - 13
6 REPLIES 6
Lee Hankins
I think one of them is part of the editing plane.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
You have set a User Origin. You can return it to the Project Origin by double-clicking the User Origin icon in the standard toolbar.
Thanks @thesleepofreason - spot on!
Ben
MacOS 12 - 13
reiki
it might not be the reason, but i belive this is conencted to the fact that my 3d window flickers, as if the editing planes intersec at a weird angle
I don't think so.
As mentioned in earlier posts, one (the black one) is a custom user origin, and the other (the blue one) is the project origin.
When you reset the user origin to the project origin, you will just see one and it will be black.
Awesome! thank you!
