LeeJaeYoung
Why does it take a huge amount of time to connect the wall and slab in the cross section?
The layer was off in the cross section, so I turned it on in the layer combination. There was no change, so I tried rebuilding and running the drawing manager, but there was no change.
All I had to do was take the object and move it into place, but this time it didn't work.
When I turned off the layer combination and turned it back on, updates became possible, and after updating, it started to work.
Next, the objects to be connected were selected and moved into place, and the connection was completed.
This phenomenon is something I often ask questions about.
Is the regen function not available in archicad?
And as you can see, this file is a very small file.
And I know that I didn't control the combination.
I also know that there was an uproar in the custom state.
However, I am asking a question about having to move objects in place even after updating the layer combination.
I would like to know what kind of phenomenon and what to do about it.
after layer combination
update
AC27 on window 11
1 Reply 1
Steve Jepson
Possibly Model Rebuild options ?
