‎2021-02-09 03:55 PM
‎2021-02-10 02:05 AM
‎2021-02-10 03:53 PM
‎2021-02-10 05:35 PM
‎2021-02-11 03:18 AM
runxel wrote:
This also bugs me. But there is a very weird workaround:
"Open" the circle with the pet palette, offset it (it works now, if the circle is just an arc!), close it again.
Very crude, to say the least.![]()
Hopefully GS will address this with 25.
‎2021-02-18 08:02 PM
Barry wrote:Thank you for the answer. Yes, actually it was what I meant. Still can't get used to the different approach in comparison to AutoCAD...
You mean when you start to drag a line and then you activate a copy?
If so, that is not truly offsetting the line.
But I don't think that is what you mean anyway.
‎2021-02-18 08:03 PM
Dontknow wrote:Wow, that's cool! Thank you! That is very good to know.
You can't offset circles or elipses as a line but you can offset them as a fill.
While you're using 'Offset all edges' press 'Ctrl' or 'Cmd' for one offset copy or 'Ctrl-Alt' or 'Cmd-Alt' for multiple offset copies.
‎2021-02-18 08:04 PM
runxel wrote:I hope that too! Thanks for the answer!
