2024 Technology Preview Program
Window / Door Dimension Marker
In AC 11 I've got trouble how save my customized settings for the dimension marker in the door or window settings, so that I won't have to change the default settings everytime I change the window or door type in a project. How can I do that?
Thanks Rasmus
4 REPLIES 4
That's strange. The door & window markers should retain their settings regardless of the door or window selected. I just checked in 11 and it is working fine for me.
That is indeed strange, if I choose one type of window and "calibrates" my dimension marker in the window settings pane, it returns to the default settings, when I choose another type of window. AC dosen't seem to store my settings, and I can't store them myself.
(I've posted a screenshot of the windowsettings if thats any help.)
Maybe its the "input" side of the monitor that's lacking.....🙂
Regards
Rasmus
I see. I thought you meant that the selected marker was changing. You mean the marker settings are returning to their default. I have used custom markers (that require no settings) for so long I hadn't seen what you describe. You are right the marker settings return to their defaults when a different door or window is selected.
The simplest fix is to open the marker and save a copy with the defaults set as you want them. Make sure that you change the name to avoid confusion.
Thanks a lot, for your effort, i'll try it ASAP.
/Rasmus
