Window Ganging - two check boxes on left-right?
rob2218
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
David Maudlin
Rob:
Which Library is that from? In the Object Library 18, there is only a W Fixed 18 window like that, which only has one ganging check box.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
rgarand
The "casing" check box simply allows you to include or exclude the casing.
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
