Window Label Issue
Chris Grantham
I am trying to use labels to tag my windows rather then than the marker option that is available within the window settings. I am doing this because I can't seem to get marker to show up as a hexagon, and it seems to work nicely for tagging in elevations. I have one particurley pesky label that does not want to rotate to be in line with the other tags. Whenever I try to rotate the label to match the others it defaults to being upside down or reading from the right as I have shown in the two images. Does anyone have any ideas? Thanks in advance!
-Chris
undefined
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
11 REPLIES 11
Chris Grantham
Picture #2
Mac OS 12.2.1
Stress Co_
Try this:
Select the wall with the uspside-down marker.
From the menu select: Edit > Modify wall > Invert Direction
Sometimes labels care which "direction" the wall was created.
EDIT: Modify wall may not be in the Edit menu (maybe in Design). This worked back in AC 9.... I'm not so sure now, but give it a try. I'm not running AC on my laptop and can't check.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Chris Grantham
Still doing the same thing...
Mac OS 12.2.1
Erika Epstein
Try using the AC11 window marker. This will allow give you all the options you want to create what you show.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Chris Grantham
Thanks Erica,
Will I still have to use labels instead on the elevations? I am not sure that there is any way to use the markers to tag windows in Elevation.
-Chris
Mac OS 12.2.1
Chris Grantham
It would seem the window markers are even more infuriating then the window labels. All I want is to get all of the tags to sit like #37 around this bay window, in a horizontal fashion. Anyone know of any good work arounds?
Thanks!
-Chris
undefined
Mac OS 12.2.1
Erika Epstein
Open the s/e.
Select all window.
In the ID box check LABEL ELEMENTS.
Select the labels and change them to the window label.
If you do a search here on the forum, this has been discussed before.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Chris Grantham
In Elevation I am trying to use the label elements option, but continue to have the same problems with the tags! They seem to default to these odd angles and I cannot get them straight...
Mac OS 12.2.1
Thanks!
-Chris
You will have to modify the Library Part used by the Marker or Label.
There is a GDL Global variable that returns the angle between the Wall of the Window and the horizontal direction. It is called WALL_DIRECTION:
http://www.archicadwiki.com/Global%20GDL%20Parameters#WALLDIRECTION
You will have to rotate the 2D of the GDL object to compensate for the inclination of the Wall the Window is placed into.
This is the theory, unfortunately I do not have time to test if it works.
