Window Markers Display on plan for stacked walls
I various reasons I have ended up stacking 2 walls on one level. There are windows in the lower wall and the higher wall. The marker for the lower wall is showing up fine on plan but I cannot get the higher one to show. Is there a way to do this?
Can you show a screenshot of how they look at the moment? From that screenshot we may be able to advise you what setting to change.
Also, how do you want your higher wall to appear? Cut? Dashed lines like an overhead element?
Use a Label.
