Windows suddenly acting weird
Kamelite
Tried to place a couple of windows, and this happens.They are grey, and doesn't show properly i 3D. How come? The lowermost window is correct, the two incircled are not...
After some trial and error, i discovered that if I deleted the wall and placed it again, it seemed to work fine. But, what happened? I picked up the properties of theese windows from another window that behaved as it was supposed to
Windows 10, Archicad 28
Kamelite
BTW, this was done in AC21...
.Kamelite
Kamelite
Problem solved!
I discovered, more or less by an accident, that the renovation status was set to "To be demolished".
Changed this to "Existing", and they both appeared!
.Kamelite
