2017-09-26
02:44 PM
2023-05-24
08:27 AM
Rubia Torres
2017-09-26 04:13 PM
2017-09-27 08:36 AM
2017-09-27 02:28 PM
2017-09-27 08:35 PM
David wrote:As with everything done in ArchiCAD, how you do it depends on what you need to do with it. Bump mapping has it's place even in a Virtual Building, but I don't think using it to replace simple geometry is a useful application of it.
oliveruszkurat:
If you are on ArchiCAD 21 you can use the new Railing Tool: remove all the parts except the Balusters and adjust their parameters to suit.
I agree with Erwin, any modeling solution is going to create a lot of polygons, so a texture will generate faster 3D views.
David
2017-09-28 08:41 AM
2017-10-01 10:22 PM
2017-10-02 08:51 AM
2017-10-02 09:51 AM
Steve wrote:SEO would be a way too heavy operation for something like this.
Would SEO be a good way to do it too?
2017-10-03 01:29 AM
runxel wrote:I change my vote to columns since they would be convenient for with Interactive Schedules too. I am not sure if you could schedule the railing option, and you certainly can't schedule the graphics options.Steve wrote:SEO would be a way too heavy operation for something like this.
Not only that, you still would need to have the SEO elements in your file (another thing to take care of!)
For me, SEO is just the last resort, when it can not be done otherwise.
I would go with the railing, but if you don't have 21 already Erwin's solution is beautiful and I deeply admire this idea.
I would not model it with walls, tho. Columns would suit it better; they can be resized fast and easy. And you can have column symbols!😉
justmy2cents
