I agree with David that this setting does not belong in WE since some users (myself included) like to switch it frequently. Although this could work if the units setting was it’s own WE subset with an available menu item, like palette profiles are now.
Putting it with dimensions is an interesting idea, but it won’t work since the whole reason for making this separate is so each TW2 user can have different settings that are not saved with the project. Which begs the question...
Laszlo, what prevents each of your colleagues from setting it up the way they like it now?
I have a keyboard shortcut set for units, which works well save a few minor quibbles. First, the decimal setting is not remembered, so if I switch from fraction to decimals I have to reset the decimals each time. Second, I would like to see text get it’s own settings. ArchiCAD doesn’t handle points properly, and I would prefer to use mm anyway. Having points hardwired to imperial units is unnecessarily restrictive.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
