Xray Material in CineRender Engine
Alanerniquez
Does anyone know how to create a Xray Material to be rendered on Archicad with the CineRender?
See Image Below
Mexico
1 REPLY 1
sinceV6
Hi.
Set color to desired blue tone; in transparency select Fresnel and adjust settings. For it to look closer to your example, I'd suggest you check "additive". You can start from there.
Fresnel effect will look better in curved objects. For planar objects, like in your example, you could play with simple transparency.
Best regards.
