‎2005-05-11 07:30 PM
‎2005-05-11 07:35 PM
‎2005-05-12 03:39 PM
‎2005-05-12 10:11 PM
‎2005-05-13 11:42 AM
‎2005-05-15 10:55 PM
‎2005-05-16 09:25 PM
‎2005-05-17 11:17 AM
Tom wrote:I don't think this is possible, I know of no such GDL commnad or Global variable that would provide this data.
Is there a way to have the zone stamp display the length and width of the Zone? It seems it has every other possible variable in it. I'm using zone identifier 2 (AC9).
The stamp must already have those values; it's calculating the area, volume, etc.
‎2005-05-17 11:19 AM
Jay wrote:Or you could create a new parameter in the 2D Script of your Zone Stamp. Depending on the state of this parameter, ArchiCAD would use either ROOM_AREA or ROOM_CALC_AREA in its calculations.
Thanks for the Help that worked. Well, at least it nowAlwaysreports the Area to the outside of the wall.... even with the Zone Polygon selected as net (showing only the inside of the walls). Looks as if I need to set-up two different Zone stamps (and therefore Zone Categories) if I want the Zone Polygon display to match the Zone Area.
‎2005-05-19 10:10 PM
