Ahoj Pepe
You can offset walls by selecting more than one and clicking on the edge of the wall you want to offset, this will stretch the other walls along with it.
See below.
You can also connect any walls using the reshape > connect / extend commands.
You can also draw a marquee around items and use the reshape > stretch command, but that might end up stretching things you don't want stretched.
In early design stages you may want to use fills, zones or morphs for massing studies as it is quicker to manipulate those than a model with walls, slabs, roofs etc
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
