‎2013-06-21 02:18 AM
‎2013-06-21 06:57 AM
‎2013-06-21 10:17 PM
‎2013-06-21 11:58 PM
‎2013-06-24 08:01 PM
‎2013-06-24 10:20 PM
Joseph wrote:Ditto....
hi,
how can i down load only the zone stamp instead of the entire library?
thanks,
joseph
‎2013-06-25 07:03 PM
Rick wrote:If the drag to ArchiCAD function is not working you should make sure the GDL Web Control/Plug-in is up to date. If that does not correct the issue then you may need to try another web browser or check to see if another application, such as anti-virus, might be impeding the process.Joseph wrote:Ditto....
hi,
thanks,
joseph
The drag to Archicad17 feature doesn't ever finish the download.
something looks like it is broken.
‎2013-06-25 09:02 PM
‎2013-06-26 12:00 PM
‎2013-06-26 06:31 PM
laszlonagy wrote:This is the first time I have tried to use the portal from a browser. I can't get any object to drag and drop.
However, I could drag any normal object.
