archiving teamwork
I have several projects that are plp and are no longer activly in CDs. I do need to access the files, but have no use for teamwork as there is little to do other than RFI updates. These files are 9 and linked to PM. Should I save them as pln and link the lbk to the pln?
1 REPLY 1
You could save as a pln or just sign in with exclusive access every time!
Hope it helps,
Michele
