dhnguyen
can't select door
I cannot select the door in "Work rm # 4" and the door to the right side of "Office # 5". Not sure what's going on. I did read this thread below:
https://archicad-talk.graphisoft.com/viewtopic.php?t=42846
and my magnetic picker is on.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Lingwisyer
Guru
Have you tried tabbing through it? Cursor over where a hotspot would be then hitting tab to cycle through what is there. It looks like your door is below your cutplane, or in a second wall that is being shown behind.
Ling.
dhnguyen
I tried tabbing, but not sure how it works. After monkeying with it for a while, i decided to delete the wall and the door automatically gets deleted with it. Thanks.
DNguyen
ArchiCAD 18- 25
