composite wall question
Hi does anyone know how to turn reverse composite walls so the external (plaster faces in) also join them up and the corners so the cavity carries around the corner.
im also trying to create a 10mm partition composite wall but it seems the thickness cannot be edit. is this true.
many thanks again
Erich
If you are using AC 16 or earlier, use the "Modify Wall Reference Line" command. You may have to add this to your work environment first.
You should add a signature to your profile with your hardware and AC version since answers can vary with either.
HTH
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Hi thanks for your reply, im in 16, could you be a little more specific as to how i would achieve this.? Many Thanks
In the wall settings dialog box, you can flip the reference line of the wall. Just browse the box and you will see it. I would post a screenshot but I'm using 17 and it's slightly different.
To create a composite wall, go to Options > Element attributes > composites. You can edit/create composite walls there (including the thickness).
