‎2004-10-27 10:46 PM
‎2004-10-29 09:11 PM
Tom wrote:
Ok Now I'm having a problem creating the symbol line type. I've tried creating the "brick" from which the symbol line would be derived in 1:100 scale, as directed in the help menu. However, when drawing the symbol line, the size of the brick is nowhere near 4" x 8". Plus, the vertical 8 inch lines are extended past the 4 inch horizontal lines. Any help on that issue?
Tom wrote:
Also, will this symbol line, assuming I ever get it drawn, show up on 3d?
‎2004-10-29 09:28 PM
‎2004-10-29 10:53 PM
‎2004-10-29 11:30 PM
Tom wrote:
Using the symbol line, I drew all the borders. I isolated the line, marquee, assumed it would show up in the 3d window to save it to a .dxf. However, they are lines, so they don't show up in the 3d window. How do I save the pattern to to .dxf?
Today, Archicad has kicked my butt.
‎2004-10-30 01:12 AM
‎2004-11-01 03:06 PM
Tom wrote:
Actually, I was able to create the DXF with the symbol line. I am able to place it as well (in the 2d plan window) after creating a .gsm object. Unfortunately, I used the same color pen as the brick...duh...so I can't tell if it shows up in the 3d. I guess I have to create it again with a contrasting line color to see if it works in 3D.
‎2004-11-01 03:49 PM
