cut fills not aligning on AC17
Hi all
Im getting to grips with AC17 this last couple of weeks. So far Im impressed with the new work flow, all seems to make sense.
But Ive come up against something odd I cant work out...
attached is an image from a 3d document Ive created. Can anyone explain why the vector fills for the two elements of my wall as well as the two elements of my terrain are not aligned as one material when they use the same Material/cut fill??
Im using renovation filters, but all the elements are all designated as "existing" so I dont think this is the problem
thanks for any help
8 Replies 8
Can you upload the file or this portion of it to Dropbox or something?
here is the PLN file uploaded to speedyshare.com:
http://speedy.sh/7fnmk/forum.pln
thanks
I am sorry but I can't download this file like that.
The site is asking me to install their download manager, which I don't want to do.
Can you put it somewhere else, like Dropbox or something similar?
Ah sorry, i didnt realise that you needed to download a program to get the file. Ill dig out my old dropbox account on monday.
I looked at the file.
Unfortunately I could not find any way to fix it. I don't know it the fact that the bottom Wall piece is a simple Wall, while the upper piece is a Composite as anything to so with it.
But there is another problem too where the Ground Floor Composite and the Attic Composite meet: there is a problem there too.
So I would suggest that you send this file to your local reseller and they will forward it to Graphisoft to look at.
Ok, thanks for taking the time to look at it anyway, much appreciated
Strange it is perfectly fine in section - just not in a 3D Document.
I even tried to invert the direction of the wall and swap reference line positions but there was no change.
Even stacking two of the same walls in the same storey shows that the fills don't match in 3D docs.
It seems the fills are not based on the origin position as they are in section.
