distance options in elevation
If you mean stepping the horizontal range and Distant Area depth the same way you can step the section line itself, I think you're out of luck. Would be great if you could.
7 REPLIES 7
Oh, multiple Distant Area Depths, that has been suggested before, and maybe even wished for. I vote essential.
Djordje
The wish exists, please vote there.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Petros Ioannou
And until your wish come true you can use two (or more) sections with the second starting at the depth-end of the first one and then overlap them in a layout. Be careful to set section lines of the second one to a thin pen, and also place it in a different (hidden) layer.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Djordje
... and play around with the pen table for the second, third, or whatever row ...
Djordje
HP Omen
TomWaltz
My dream has always been a system that says
"For every X feet away, subtract Y from the current pen", with Y being either a pen value (adjusting pen 1 to the left), or a weight (remove .02 mm) or a color (make 5% lighter)
Tom Waltz
Petros Ioannou
well my dream would be a printer which could print so acurrately and a pair of eyes that could tell the difference...
Still it's a good idea Tom.
32 GB 2400 MHz DDR4
SeaGeoff
Ace
Or better yet a continuous gradient.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
