door trim issue in Complex Profiled Wall
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2008-11-20 05:07 PM - last edited on ā2023-05-26 11:29 AM by Rubia Torres
It is a D1-12, but happens with other doors also.
Trim only stands off on one side, opposite of swing of any door.
Seems I've gotten this solved once before, but looking at parameters for wall and door, I have not been able to locate it, yet....
Thanks
Bier
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-11-20 06:54 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-11-20 07:42 PM
With proper reference lines and with wall embellishments at base and crown, I found that in some cases, doors/windows would only place themselves in the wall properly if they were lifted above the base or below the crown. Some elements cut the crown properly and not the base; others cut the base properly and not the crown.
I have not found a workaround.
So...if other readers are running into problems, please post a screenshot of your issue and identify which library part is involved and where your opening reference lines are in the profile editor.
Thanks,
Karl
AC 28 USA and earlier ā¢ macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-11-20 07:48 PM
You can see that the door brings the frame and casing to the outside face of the base moulding when the door is inserted at the base of the wall, where it belongs. When moved into the wall, or even up into the crown, the door appearance is correct - and the crown is even cut.
(Windows had the opposite behavior - they would cut the base moulding, but not the crown.)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-11-20 07:49 PM
Anyone else running into these kinds of things?
Thanks,
Karl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-11-20 08:03 PM
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-11-21 02:16 AM
My C.P. reference opening line was away from my C.P. wall edge, now corrected, but unfortunately that was not the problem, (I did a double check
on that).
However, have now worked with the D1 door some more and found out:
1. If I set the height of the bottom of my door 1/8" (or more) above top of slab all goes back to normal.
2. If I then try to lower the door back to 0" from the dialog box, the casing goes wack again.
3. However, I can drag the door down below the slab even an inch or two to negative numbers and casing stays ok.
4. Then tried to raise door bottom back to 0" in dialog box and door goes wack again!
5. And, if I set the bottom of door to a neg number, all is ok also!!
So, my conclusion is that D1 12 (or others) mostly do not like 0"
Bier
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2008-11-21 05:02 AM
Thanks,
Karl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2022-04-02 04:58 PM
I think it is related with this thread on our forum.
https://community.graphisoft.com/t5/Design-forum/Complex-profile-wall-door-plan/m-p/242906#M129182
