how can i make the slab above line of story level ?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-09-07
10:07 AM
2023-05-25
05:43 PM
Rubia Torres
2011-09-07
10:07 AM
so i want to change this default to make slab become automatically above floor leveling and so i can build wall above it until the next floor level here is the image attached clarified what i want
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-07 10:16 AM
2011-09-07
10:16 AM
The default is however you set the tool when nothing is selected so all you have to do is set the slab and wall tools as you wish. If you need to recall the settings often you can make them favorites. You can also use the gravity function when placing walls (and other stuff) to drop onto the slab (or roof or mesh).
What you want top do seems strange though. Is this common practice in Egypt? I have always seen the floor level set to the top of the floor (sometimes top of slab sometimes top of finish floor.
BTW: Good luck over there. I wish you all the best in building a new future for your country.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-07 11:49 AM
2011-09-07
11:49 AM
Thanks Matthew for your words wish you the same too, yeah that is the common in Egypt and some Arab countries i will try to make it as a favorite and use gravity of wall upon slab i was wishing another method rather than gravity tool but it seems this is a solution can be done
Good luck for you as well and thanks
Best regards
Best regards
