You have to make some changes to the parameters of the Elevator, I believe.
If you go to the Parameters panel of the Settings Dialog, under Stories, you will see the
Lift Overrun parameter, which you should set to zero.
Or, you can turn OFF the
Show Elevator Shaft parameter, which will not generate the walls of the Elevator shaft and you can draw them to be the height you need.
