line thickness setting
Hello
I want to set line with various thin or thickness, how can it be done?
Thanks
1 Solution
Eduardo Rolon
This is a basic question so you should check the manual, help and example files.
The answer is that Line Weight is controlled by the Pen Settings (which you should configure to your liking) and you choose them in the pen icon which has "62" in your screenshot.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
Eduardo Rolon
AC29 US/INT -> AC08
OK show true line weight then pen /color setting
Thanks Ejrolon
