ā2005-07-25
04:34 PM
ā2023-05-26
03:14 PM
Rubia Torres
ā2006-06-22 06:20 AM
ā2006-06-22 07:01 AM
'Fit In Window' . . . sometimes works, sometimes not. it's good in 10.Yes, in AC10 Fit in Window is good and made even easier by double clicking your mouse wheel button.
Your height in perspective view corresponds to which story you're on when you open the 3d window.Not sure if I understand what you mean there Bruce, but you canuse the flyout from the Navigator Preview to switch it to look from the side. You can see where your camera is pointing. If it's pointing straight up or down, then there's a problem! You can either point it in the right direction or drag your stories up.
ā2006-06-22 06:08 PM
Link wrote:Thanks, I did not know that.
Link.
ā2006-06-23 05:36 PM
Link wrote:I have seen you mention the double clicking the wheel mouse button to zoom extents several times and have tried this without success. All my other mouse function work correctly and was curious if there is any setting in Archicad relating to this. Are you on a PC? Have other Mac users been successful with this technique? It seems like great functionality if only I could get it to work.
