ā2025-04-08
11:12 PM
ā2025-04-09
01:28 PM
Hi there!
In full screen mode the window 'tracker and coordinate input' disappears. After pressing arrow up or down will popup one window for input. I tried to switch the video card mode & changing the appearance of the Tracker, but nothing helps.
Is there any way to fix this?
This is present in the 27th and 28th versions, as far as I know.
Thanks!
MacBook Pro M3 max, last OS (doesn't matter)
ā
ā
ā2025-05-08 10:06 PM
Does this happens when using a default Work Environment (WE)? Try it with a default WE.
ā2025-05-09 11:41 AM
Unfortunately the same results.
It's a very strange no one haven't same problem or people don't work in fullsreen mode?
Or do people who work not visit forums?
ā2025-05-09 11:51 AM
I'm on a M1 Max MacBook Pro using macOS Sonoma (14.6.1).
Tried it on AC27 and AC28 without any issues (both on the MacBooks screen and a mirrored Apple Studio Display). Are you using two displays contemporarily?
Is it possible that the tracker is on the second screen?
ā2025-05-09 01:00 PM
I have MBP only
ā2025-05-09 01:05 PM
Recently (two years) I reinstalled the operating system cleanly twice and used versions 27 and 28. It was always the same problem.
Have you tried to turn "off" then "on" the tracker?
Also, are you using any special add-on?
ā2025-05-09 01:10 PM
Sorry for asking, are you installing AC 27's or AC28's apple silicon version?
ā2025-05-09 01:14 PM
yes and tryed to use custom appearence (((
ā2025-05-09 01:17 PM
š¤
