2025-04-08
		11:12 PM
		2025-04-09
		01:28 PM
Hi there!
In full screen mode the window 'tracker and coordinate input' disappears. After pressing arrow up or down will popup one window for input. I tried to switch the video card mode & changing the appearance of the Tracker, but nothing helps.
Is there any way to fix this?
This is present in the 27th and 28th versions, as far as I know.
Thanks!
MacBook Pro M3 max, last OS (doesn't matter)
2025-05-08 10:06 PM
Does this happens when using a default Work Environment (WE)? Try it with a default WE.
2025-05-09 11:41 AM
Unfortunately the same results.
It's a very strange no one haven't same problem or people don't work in fullsreen mode?
Or do people who work not visit forums?
2025-05-09 11:51 AM
I'm on a M1 Max MacBook Pro using macOS Sonoma (14.6.1).
Tried it on AC27 and AC28 without any issues (both on the MacBooks screen and a mirrored Apple Studio Display). Are you using two displays contemporarily?
Is it possible that the tracker is on the second screen?
2025-05-09 01:00 PM
I have MBP only
2025-05-09 01:05 PM
Recently (two years) I reinstalled the operating system cleanly twice and used versions 27 and 28. It was always the same problem.
2025-05-09 01:05 PM
Have you tried to turn "off" then "on" the tracker?
Also, are you using any special add-on?
2025-05-09 01:10 PM
Sorry for asking, are you installing AC 27's or AC28's apple silicon version?
2025-05-09 01:14 PM
yes and tryed to use custom appearence (((
2025-05-09 01:17 PM
