Thursday
Hi there,
How would i change the marker head from a triangle to a circle in archicad 29?
There seems to be an option to change the marker head in older archicad versions but not here.
Solved! Go to Solution.
Thursday
I don't use change markers.
But it looks like you can't be using the 'built-in' marker.
Change it to the 'basic' one instead.
Thursday
If you mean section and elevation markers, it should all be the same as before.
In the section/elevation settings.
Thursday
- last edited
Thursday
If you do not have the options Barry is showing, check which marker you are actually using.
Ling.
Thursday
Sorry, no I mean for change marker.
It only shows it like this...
Thursday
Thursday
Thank you.
