2026-07-23 07:26 AM
Hi there,
How would i change the marker head from a triangle to a circle in archicad 29?
There seems to be an option to change the marker head in older archicad versions but not here.
Solved! Go to Solution.
2026-07-23 09:05 AM
I don't use change markers.
But it looks like you can't be using the 'built-in' marker.
Change it to the 'basic' one instead.
2026-07-23 07:35 AM
If you mean section and elevation markers, it should all be the same as before.
In the section/elevation settings.
08:37 AM
2026-07-23
03:05 PM
If you do not have the options Barry is showing, check which marker you are actually using.
Ling.
2026-07-23 08:42 AM
Sorry, no I mean for change marker.
It only shows it like this...
2026-07-23 09:05 AM
2026-07-23 12:19 PM
Thank you.
