multiple Shells = slow rebuild
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-12-12
05:29 PM
2023-05-23
04:33 PM
Rubia Torres
There are probably several hundred of them on this project, on multiple levels. Rebuild time has slowed way down.
Any way to simplify the shell or anything else to speed up rebuild?
After sizing, baluster file size is only 7 KB.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-13 05:44 PM
You can download and install the Polygon Count goodie. It will be able to tell you.
If the polygon count is high then maybe the GDL script should be modified.
Resolution of curves is 36 by default, which means a simple cylindrical shape is at least 36 polygons, a simple shere is 1296 (36x36) polygons.
You can place a command at the beginning of the 3D Script, for example setting the resultion to 16 (which means a full circle will be made up of 16 segments):
RESOL 16This will set the resolution of curves to 16, resulting in much less polygons.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 02:34 PM
laszlonagy wrote:Laszlo:
I looked at this approach (there is even a resol statement in the generated script), but the command revolvedshell ignores the resol statement, so the resolution cannot be altered this way.
He could try using the Profiler goodie, which generates a 3D Script that uses the resol statement.
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 02:51 PM
So maybe it is controlled by the TOLER command, which is the equivalent of the Deviation from Curves setting of the Magic Wand Settings Dialog.
Or the third possibility is the RADIUS command.
These three are the ones used to control the resolution of curved surfaces and Arcs in GDL.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 04:49 PM
The level of detail is set to "off" although I'm not sure what it means or what effect it has on the rebuild.
Also tried using the profiler which is a AC 16 command. There is no profiler in the goodies download for AC 16, so am not sure what you are referring to.
I gather from your responses that there is no way to create the baluster without all the polygons.... no way to simplify it?
See the attached jpeg for the profile I am attempting.
Any other suggestions? What about making a morph out of it.....would that help?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 04:53 PM
Tom
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 05:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 05:25 PM
Tom
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 05:26 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 05:28 PM
