2006-09-24 10:09 PM - last edited on 2023-05-26 12:23 PM by Rubia Torres
2006-09-24 11:17 PM
2006-09-25 03:01 PM
2006-09-25 04:50 PM
Stephen wrote:I noticed this this weekend -- don't know if it's intentional or a bug -- LJY.
I just noticed when walls are created using "outline only", doors and windows do not show up. Is this a bug?
2006-09-26 05:49 AM
2006-09-26 07:47 AM
Stephen wrote:this is probably intentional isn't it? the 'outline' method of displaying a wall is intended as a non-cut, top-down view . . . therefore wall openings wouldn't show would they? if you are trying to hide wall hatching and skin lines through a wall that passes through the cut plane you should use the model view options rather than represent the wall in a fundamentally different way.
2006-09-26 07:59 AM
2006-09-26 08:27 AM
Erika wrote:yep. graphisoft are clearly trying to move away from a graphically represented plan view. sections and elevations are already model views but the plan is hanging back in the dark ages (think SEOs). i think the wall display-type principle should run something like this...
What you says makes sense as we can already control the wall showing as outlines and windows with our display options.
