profile wall vs dome shape
I was doing some seo with prifile curved walls (dome shaped) and was running on some performace issues. I was wondering will using dope shape from library spreed things up? How will that affect my performance?
Thanks
4 Replies 4
You should just try it yourself because you have the file and the computer where this occurs.
But I can imagine that the Dome object is faster, being simpler than a Profiled curved Wall. Also, when the 3D of an object is first generated a sort of binary code is generated so it will generate in 3D faster later on.
Dwight
However, if you are making a complex dome with many reveals and protrusions requiring the complex profile, the resolution of the dome can be controlled.
Use the magic wand inside a circle and specify the number of segments.
This will facet your dome and reduce polygons.
Dwight Atkinson
Thank you for a great tip.
I was thinking of making it with the walls, and than saving the whole thing as a object. Maybe that will reduce loading times.
It looks like seo add that time for loading. When there are just walls, everything looks fine, but when I start slicing them, than there are problems..
Ralph Wessel
Try using OBJECTiVE. You can make your dome shapes, control the detail and speed of redraw, and cut the shape up without SEOs. Referring to the attached image:
  • 1. OBJECTiVE provides profiling tools that can create swept shapes like a dome.
    2. The settings for the profiled objects includes a parameter to control the faceting (the tolerance in this case), so you can decrease the object smoothness if the 3D display is becoming too slow.
    3. OBJECTiVE also provides a Split tool, which can cut objects up with using SEOs. The advantages include faster redraw, simpler application, no hidden objects hanging around, and correct display in plan.
    4. The cut dome in 3D.
    5. The same object in 2D - note the cut is displayed accurately.
Ralph Wessel BArch
Central Innovation
