question with fills ---2 more questions
hi I have other 2 questions about fill tool:
1. when I rotate a fill of tile patterns from horizontal position to say, 30 degrees, I want the tile patterns rotate with it. But it seems that no matter how I rotate the whole thing, the orientation of the pattern stays the same (please see the attached files to this post). How can I make the fill pattern rotate as well?
2. How can i rotate the fill pattern only, with the boundary unchanged?
thank you guys!!!
3 Replies 3
Dontknow
Make a new fill pattern with the rotation angle and use that one.
Options -> Element attributes -> Fill types.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
thank you so much for your help!!
David Maudlin
In the Fill Settings > General Settings > Construction Methods: select the Relative to the Fill Origin option, this provides a handle for rotating the fill within the boundary and moving the fill's origin.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
