2014-04-01 06:25 PM - last edited on 2023-05-24 09:01 AM by Rubia Torres
2014-04-02 12:01 AM
2014-04-02 07:48 AM
NCornia wrote:
Jonathan,
Open the door settings and change the Wall Closure to Custom or Solid. This should allow the reveal to change. I will have the team review the Stud Wall closure to learn the reason it is so rigid and does not allow a reveal.
Please note that when you change the wall closure your door display may change and you may need to adjust the tolerances and possibly other settings depending upon your configuration.
2014-05-06 03:21 PM
NCornia wrote:This is not a solution. There are certain options available and not available with each wall closure type. Changing the wall closure eliminates other options that a user may want to utilize, as well as resetting other parameters they may have already set up.
Jonathan,
2014-05-06 05:30 PM
