2024-01-29
08:33 AM
- last edited on
2024-02-04
11:09 PM
by
I may miss something but why there's no multisegmented revolved column ( not extruded ) ? When i need multisegmented column, i have to use railing post, why this very basic column function doesn't exist ( i don't want to use morph ).
I would like complex profile ( where is can build multisegment, multiple material ) then simply revolve it with column tool, not railing post. It's possible on railing post, why not on column ?
2024-01-30 10:46 AM
As far as I know you can do that but custom profile needs to be used as beam
2024-01-30
11:33 AM
- last edited on
2024-02-04
11:11 PM
by
But you wont be able to complete 360 deg. What's i'm asking is complete revolution 360 deg. then i will be able to do the following light. For now, i use railing post which support multisegment complex profile.
2024-01-30 12:59 PM
Instead of Morphs you can use Shells but they have a limitation with small radii.
2024-01-30 02:42 PM
You can also use a curved (circular) complex profile wall.
2024-01-31 02:14 AM
I do lights like these with Revolved Shells. Sometimes I split the hanger from the head and save them as seperate objects, copy them into a single object, add a 5 or 10mm cyclinder and a hanger length parameter, and now I have a height adjustable light.
Ling.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2024-02-20 03:00 PM
so, nothing work as well as railing post, i really wonder why multisegmented custom profile doesnt exist in column as it exist in railing post, i really wonder why
2024-02-20 03:03 PM
so, nothing as efficient, fast and parametric as railing post then. It's also easy to adjust the height of any part by just adjusting custom profile.
2024-02-21 02:16 AM
There might be a wish around somewhere for it, though I do not recall seeing one, so if that is the case, make a wish?
