ā2015-03-01
05:07 PM
ā2023-05-24
07:01 PM
Rubia Torres
ā2015-03-02 01:30 PM
ā2015-03-05 03:14 AM
ā2015-03-08 06:38 AM
ā2015-03-08 09:06 PM
laszlonagy wrote:It could be. In SolidWorks or CAtia, I can cut any solid in any way I want and all created surfaces can be individually selected and modified in very simple way, but again SW and Catia are much more advance softwares. Too bad it is not possible in Archicad, it doesn't look like it is a complicated issue for software programmers.
I am afraid this is a limitation of the program because those are cut surfaces which are shown with the Surface defined for the Building Material of the Shell. So actually you would have to change the Surface setting of the Shell's Building Material, and I don't know if that is feasible for you or not because at other places where the Shell is cut in 3D it might not give you correct results.
ā2015-03-09 12:12 AM
ā2015-03-09 01:39 PM
