small caps
I'm pretty sure that I'm out of luck, but does anyone have a work around
for the text tool to take advantage of a font that provides the "small caps" option?
Aaron Bourgoin
Wally,
Can youexpand on that question. AT first glance this would seem like a OS issue?
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
Aaron,
When using the text tool we are offered the choices of Italic, Underline, or Bold text. I have a couple of fonts that when used in any of my word processor programs allow the selection of "small caps" as well as the above options. These fonts have both upper and lower case letters and if, on the fly, I switch to small caps the size of the new caps matches the lower case letters. Since there is no selection for this in the text pallet I was hoping someone had a solution. The font I would like to use is named "Tekton Pro".
cheers,
